vlan.msgs.PortLinkFlapActDsblPort
Description
This message is displayed if a user has enabled link-flap detection on a port and has set the action to disable the port on exceeding the configured threshold value for link flaps. The severity is set to debug-summary to avoid duplicate messages from being printed, if the link-flap detection log action is also enabled for this port.
Remedy
No action required - Notification message only.
Severity
Debug-Summary
Message Text
Port %slotPort% is disabled for excessive link flapping. Link has flapped more than %linkFlapCount% times in %interval% seconds.
Message Parameters
Name Type
slotPort SlotPort
linkFlapCount uInt32
interval uInt32
